Does anyone know if you can add a pressure pipe lable in a section view?
If you select the pipe, the contextual menu doesn't show any labeling icons and if you right click "All label" isn't there either.
I believe this is the limitation of the software so labeling pressure pipe in a section views is not possible.
You may provide a feedback about this feature or create a wish list here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
