Civil 3D Forum
pressure pipe label-Nominal Diameter
2 REPLIES 2
1458 Views, 2 Replies
Hi Attched shows a pressure pipe which has a "Nominal Siameter and Material " label as default. But, I don't know why it shows 150mmx150mm diameter instead of just 150mm!! Thanks Hamid
2 REPLIES 2
Jay_B
That value is being pulled from the sqlite file and can easily be edited using the "Content Catalog Editor".
To open the Content Editor go to Windows Start Menu > All Programs > AutoDesk >
AutoDesk AutoCad Civil 3d 2014 > Content Catalog Editor
Then open the sqlite catalog the Pressure Network uses and change the value as shown in screen capture.
Note: if your unsure where the content catalog is currently mapped, verify by entering
 _AeccSetPressureNetworkCatalog @ the command line.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
Thanks for your follow up,but content catalog doesn't show anything for me!
Rail Community
