Hi Attched shows a pressure pipe which has a "Nominal Siameter and Material " label as default. But, I don't know why it shows 150mmx150mm diameter instead of just 150mm!! Thanks Hamid
Solved by Jay_B. Go to Solution.
That value is being pulled from the sqlite file and can easily be edited using the "Content Catalog Editor".
To open the Content Editor go to Windows Start Menu > All Programs > AutoDesk >
AutoDesk AutoCad Civil 3d 2014 > Content Catalog Editor
Then open the sqlite catalog the Pressure Network uses and change the value as shown in screen capture.
Note: if your unsure where the content catalog is currently mapped, verify by entering
_AeccSetPressureNetworkCatalog @ the command line.
