I created a pressure pipe with no bends since my alignment is fairly straight. However, I'm changing the elevations on the pipe using a combincation of the profile view snaps and elevation edits in the properties and it doesn't restrict my deflection to my deflection settings not does it add any bends.
Is this still a missing function in Pressure Networks? Or is there something I'm missing?
I took a look at this, and if I understand you correctly, I do not think you are missing anything. The functionality you are describing does not seem to be part of the pressure pipes in 2013.
I would suggest you make your festure requests by following this link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
