Valued Contributor
hamid.akbari
Message 1 of 5 (313 Views)
pressure pipe-bend less than 11.25
313 Views, 4 Replies
10-16-2013 10:20 AM
Hi
I have a watermain project and am going to design by Civil3d2013.
I just realized that Civild3d has 90-45-22.5-11.25 which are excellent for waterworks.
What should I do for degrees less than 11.25 .
thanks
Hamid
Two options, in the parts list (assuming you want to use the deflection option mentioned before) set the allowable deflection of the pipes.
Second option, create a new part with the deflection you need. Check out the instruction file that gets installed with Civil 3D: "C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Civil 3D API\Part Publishing Wizard\PartPublishingWizardUsersGuide.docx" (note: that's the default install location)
Valued Contributor
brian.strandberg
Message 2 of 5 (295 Views)
Re: pressure pipe-bend less than 11.25
10-16-2013 11:55 AM in reply to: hamid.akbari
Check the manufactures pipe dimensions.  For 12" Ductile Iron you can deflect up to (don't quote me, check for yourself) 5 degrees 20 minutes of deflection.  Civil 3d will allow you to deflect a pipe at a fitting or pipe / pipe intersection.  (see the image).
Check this link for deflection angles for ductile iron pipe (mechanical joints)
http://www.american-usa.com/products/ductile-iron-pipe-and-fittings/unrestrained-joint-pipe/mechanic...
Hope this helps,
Brian
wfberry
Message 3 of 5 (255 Views)
10-17-2013 06:15 AM in reply to: hamid.akbari
If you don't understand how rolling a fitting works, go ask a plumber to demonstrate it for you.
Bill
Valued Contributor
brian.strandberg
Message 4 of 5 (222 Views)
10-24-2013 09:44 AM in reply to: hamid.akbari
Were you able to fix the problem???
BrianHailey
Message 5 of 5 (215 Views)
10-24-2013 10:16 AM in reply to: hamid.akbari
Brian Hailey
CAD-1.com
My Blog
