Civil 3D Forum
pressure pipe-bend less than 11.25
4 REPLIES 4
hamid.akbari
1300 Views, 4 Replies
Hi
I have a watermain project and am going to design by Civil3d2013.
I just realized that Civild3d has 90-45-22.5-11.25 which are excellent for waterworks.
What should I do for degrees less than 11.25 .
thanks
Hamid
4 REPLIES 4
Check the manufactures pipe dimensions.  For 12" Ductile Iron you can deflect up to (don't quote me, check for yourself) 5 degrees 20 minutes of deflection.  Civil 3d will allow you to deflect a pipe at a fitting or pipe / pipe intersection.  (see the image).
Check this link for deflection angles for ductile iron pipe (mechanical joints)
http://www.american-usa.com/products/ductile-iron-pipe-and-fittings/unrestrained-joint-pipe/mechanic...
Hope this helps,
Brian
I rarely have time to post. If what I post helps please use Accept as Solution / Like when appropriate.
Check out my Civil 3d blog at: http://c3dk.com/
wfberry
in reply to: hamid.akbari
If you don't understand how rolling a fitting works, go ask a plumber to demonstrate it for you.
Bill
Were you able to fix the problem???
BrianHailey
Two options, in the parts list (assuming you want to use the deflection option mentioned before) set the allowable deflection of the pipes.
Second option, create a new part with the deflection you need. Check out the instruction file that gets installed with Civil 3D: "C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Civil 3D API\Part Publishing Wizard\PartPublishingWizardUsersGuide.docx" (note: that's the default install location)
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
