Longtime C3D user, new to pressure pipes though. It seems one cannot mask pressure fittings in plan view. Is that correct?
Using C3D 2014
Solved by tcorey. Go to Solution.
Hi Mark,
You can change the fitting style to Display as User Defined Block and use a block that includes a wipeout. You might have to go back after placing the network, pick the fitting blocks and change Display Order to Move to Front. You can pick one and use Select Similar, so it only takes five seconds.
Tim
