Civil 3D Forum
portrait cross sections
2 REPLIES 2
lambertb
260 Views, 2 Replies
I am on to something but a bit stuck. I am trying to set up portrait cross sections. I can get my views to create a grid and such that look correct, however when putting them on sheets, it rotate the border, but also the modelspace. Are there certain settings in the sheet creation or the dwt file I need to review to do portrait sections?
C3D 2022 and 2024
2 REPLIES 2
sboon
in reply to: lambertb
I've never seen anyone else trying to create section views in this way.  The software is set up to present them in a normal horizontal layout and I cannot see any way to force it to show them rotated as you want.
I have to ask why you're trying to do this.  It's certainly possible to layout the sheet in Landscape so that you can view and edit the sheets in a normal viewpoint, and then rotate them to Portrait during the plotting operation.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
AlmasSuljevic
I agree with sboon and think that better way would be to use portrait plot setting. One other thing you may try to use MVSETUP command and rotate your view. It may not look pretty but it can be done.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
