Active Contributor
wvyhonsky
Message 1 of 5 (2,586 Views)
Pond contour areas / volumes
2586 Views, 4 Replies
08-24-2011 05:37 AM
I remember in LDT there was way to create a pond database or something by selecting polylines. From there you could get a volume report, and areas of each contour.  Is there anything similar to that in Civil 3D?  I have about 40 new pond areas and would like to get some quick areas of each contour per lake and be able to view/print some kind of organized report.
Thanks!
Civil 3D 2009
Civil 3d 2012
Stage Storage possibly?
Once you have the stage/storage data, press the 'Create Report' button on the bottom of the dialog box and it will generate a tab-deliminated text file for you. Do this for each pond, then you can merge that data into a single text file, word document, or Excel spreadsheet. I do it all the time.
Product Support
SethHall
Message 2 of 5 (2,585 Views)
Re: Pond contour areas / volumes
08-24-2011 06:25 AM in reply to: wvyhonsky
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
Active Contributor
wvyhonsky
Message 3 of 5 (2,544 Views)
08-24-2011 01:44 PM in reply to: SethHall
Great...that is what I was looking for.  Now if could only append each basin report into one file.
Valued Mentor
ccoles
Message 4 of 5 (2,539 Views)
08-24-2011 01:54 PM in reply to: wvyhonsky
Windows 7 64-bit
HP Z600 8 Gig RAM
Civil 3D 2013
Active Contributor
wvyhonsky
Message 5 of 5 (2,531 Views)
08-24-2011 02:05 PM in reply to: ccoles
Thanks.  Sounds like a good plan!
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
