Hi-
We just upgraded to 2013, and one computer is having a weird issue. There is nothing in the drawing. He draws two polylines. When he goes to fillet them, it says they are non-coplanar. The properties palette says both polylines are elevation 0. Does anyone know why this is happening and how I can fix it?
Thanks so much!
Meredith
Solved by neilyj666. Go to Solution.
I. Verify there is no UCS in effect
II. Apply Basic troubleshooting techiniques:
A. Isolate the source
1) Is it specific to the computer?
a) Open the file on other machines
b) Test using a new default user profile
2) Is it specific to the file?
a) Check file for corruption (Audit)
b) Test on new file from clean default template
3) etc.
Do the polylines display an extrusion (that is Z= -1)?
