Civil 3D Forum
polyline elevations do not match the listed output in a strange way
2 REPLIES 2
katygurin
239 Views, 2 Replies
When I  change the elevations of polylines through the properties panel, the elevations of these lines do not match the listed elevations. Interestingly, every time I change the elevations in the properties panel the difference between the successive elevation changes is added to the elevation output in the list report. It works for positive and negative elevations. Crazy, huh? Any ideas as to why this would happen?
Thank you,
Katy
2 REPLIES 2
Citadel2012
in reply to: katygurin
Thank you,
Katy
Won't be able to tell you much without knowing what version of CAD you're running. Have you tried just saving and closing and trying to repeat the strange behavior? What are you using to generate the list with elevations?
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
Jeff_M
Was this drawing originally created in Microstation?
Rail Community
