Valued Contributor
mnyrac
Message 1 of 14 (2,762 Views)
Polygonal Viewport question
2762 Views, 13 Replies
11-19-2012 09:13 AM
I am working in Civil 3d 2012 and I want to create a polygonal viewport.  Simple enough:  View, Viewports, Polygonal viewports, and then I draw my viewport.  The view comes in as expected, but when I click on the viewport to change the properties (scale, locking), it only gives me propoerties of a polyline.  If I delete the "viewport", it leaves the view but deletes the polyline border.
What am I missing?
Caryn
troma
Message 2 of 14 (2,760 Views)
Re: Polygonal Viewport question
11-19-2012 09:17 AM in reply to: mnyrac
Is it possible that it's creating the viewport on a frozen or off layer?
I generally already have a viewport, and then make it polygonal afterwards by drawing a polyline and using the VPCLIP command.  You could test out that method to see if it makes a difference.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
mnyrac
Message 3 of 14 (2,757 Views)
11-19-2012 09:20 AM in reply to: mnyrac
Nope, I checked the layer and still the same thing.  I did wind up using CLIP instead and that will work, but I don't understand why polygonal viewport wouldn't work the way a normal viewport works.
troma
Message 4 of 14 (2,751 Views)
11-19-2012 09:35 AM in reply to: mnyrac
Glad you got something to work.
I don't have 2012 and I don't use that command, so I really can't comment.  Maybe someone else will help you more.
Jeff_M
Message 5 of 14 (2,744 Views)
11-19-2012 09:55 AM in reply to: mnyrac
Turn Selction Cycling on (CTRL+W). Then, when you select the "Viewport" (you normally will get the pline since it was created last) you will see a selection box allowing you to specify the viewport instead of the polyline.
New Member
2pinnelli
Message 6 of 14 (2,736 Views)
11-19-2012 10:24 AM in reply to: mnyrac
Caryn,
I think you will find if you select the viewport with a crossing you will be able to edit it in the change prop box.
Neilw
Message 7 of 14 (2,709 Views)
11-19-2012 03:35 PM in reply to: mnyrac
When you create a clipped viewport either by selecting a polyline or by drawing one after initiating the command, Autocad creates a viewport that is associated with the polyline. You will note that if you draw a crossing window over the polyline you will actually select both the polyline and the associated viewport (look at the properties palette to see there are 2 entities selected). Autocad has behaved this way for as far back as I know.
As has been mentioned, use selection cycling to select the viewport (most efficient), or use the crossing window and then select the viewport object in the properties palette. You can also use display order to bring the viewport object to front if you want to make it the first object selected.
FYI, you can manipulate the viewport clip by modifying the polyline with PEDIT. You can add or remove vertices and drag the grips to adjust the clip boundary.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
troma
Message 8 of 14 (2,690 Views)
11-20-2012 05:45 AM in reply to: Neilw
I think there is something deeper than that going on with the original poster's machine.  mnyrac said that using the VPCLIP worked, drawing polygonal didn't.  Also that deleting the polyline kept the view, ie the view of model space still there.  From this you can see that the polyline and viewport are not associated with eachother as they should be.
If all is working correctly, you shouldn't need a crossing window.  As long as I remember (not as long as others here, I know) you just click on the viewport/polyline once, and both objects are selected.  New for 2011: the viewport is automatically the active options in the properties pallete, rather than displaying "All (2)" and requiring the user to select Vewport in the drop-down.  The polyline is still in the selection set and can be selected from the drop-down if wanted.
It was clear to me that the OP was not getting either of these two options, and that OP understood how it should be working, and that it wasn't.  Have you ever deleted the polyline without the view disapearing?  There is something deeper going on here than a user who doesn't know how to select the right object.
Valued Contributor
mnyrac
Message 9 of 14 (2,683 Views)
11-20-2012 06:33 AM in reply to: troma
Thanks for the information.  I wouldn't doubt that there is something else going on within my Autocad, because I have also had issues with not being able to print raster images (to any printer or to a pdf).
When inserting a regualar viewport, it works as expected.  When I insert a polygonal viewport is when I can't select the viewport.  I have cycling on and it shows the viewport in the selection, but it doesn't allow me to select it.  Only the polyline.
I was able to manipulate the viewport after using Vclip.  It seems as though the problem remains strictly within the polygonal viewport command.
Caryn
Valued Contributor
mnyrac
Message 10 of 14 (2,671 Views)
11-20-2012 07:04 AM in reply to: mnyrac
When playing with it again this morning I will take back what I said earlier.  Cycling DOES work and also when I window around it, I can select both the polyline and the viewport to get properties and delete it.
So I get the extent of the issue is that the polyline and the viewport are not connected.
