Hello everyone, I was ask this question the other day "Where are points stored in civil 3D?" I stated If you import them in through a file into the drawing they reside in the drawing. I f you import them from a data collector they resided in the survey data. Was I correct?
Solved by Jay_B. Go to Solution.
Points can reside in 2 places in Civil 3D:
1. The Drawing.
2. A Survey Database which is an external file. (These can be also added from ascii or fbk files etc.)
