Civil 3D Forum
points
0 REPLIES 0
Message 1 of 1
90 Views, 0 Replies
points
Two questions: 1) Can a warning dialogue be turned on when a point is moved or deleted? 2) Is there an easy way to delete points from a project? The two ways I have come across are not desired. One by editing points (panorama), then selecting all by using shift and arrow down (very slow), then delete. Is there a select all option in this dialogue box? Two by using CAD delete, which is somewhat dangerous if you have a lot of points and some other objects may be in the mix. Thanks, plt
0 REPLIES 0
Rail Community
