AutoCAD Civil 3D General Discussion
Valued Contributor
0 Kudos
Post 1 of 8
Points - User Defined Properties
285 Views, 7 Replies
11-08-2012 12:24 PM
So - user defined properties for points are great.  My only problem is that I can't copy and paste them between drawings without losing the user defined properties.  Anyone figured out a way to do this?  I've tried it in both c3d 2011 and 2013.
I can export them into a user defined point file and import them into another drawing the same way, but that is more cumbersome than just copying and pasting.
C3D - 2014, Sincpac Addon
Land Surveyor
*Expert Elite*
308 Kudos
Post 2 of 8
Re: Points - User Defined Properties
11-08-2012 03:21 PM in reply to: paulgalli5397
You can Drag-n-Drop user defined property classes between drawings using the Settings tab of Toolspace.
The Styles Manager does not help with this. You have to use Toolspace.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
0 Kudos
Post 3 of 8
01-23-2015 09:57 AM in reply to: tcorey
How do you do this?  I have used this method to copy many styles from drawing to drawing, but I cannot get it to work with a User-Defined Properties Classification.
I am in the Settings tab (master view) select the drawing that I want to drag-n-drop from.  I expand Point item and expand the User-Defined Properties Classification folder and see me UDP Classification.  When I try to drag it into my active drawing, nothing happens.  What am I doing wrong?
I am using Civil 3D 2014.
Thanks for any suggestions.
*Expert Elite*
912 Kudos
Post 4 of 8
01-23-2015 12:37 PM in reply to: hbisco
In the data gridview select each UDP in the UDP Classification and drag them over individually.
Jeff_M, also a frequent Swamper
Member
0 Kudos
Post 5 of 8
01-26-2015 07:43 AM in reply to: Jeff_M
Thanks Jeff_M, that works great!
I had tried that before, but I was selecting multiples in the grid to drag and drop.  Selecting them one at a time is the key.
Member
0 Kudos
Post 6 of 8
01-27-2015 01:53 PM in reply to: hbisco
Well, maybe it didn't work after all.
I am copying the UDP items from drawing A into drawing B.  As I drag and drop from A into B, I see the little sqaure and the plus sign so it looks like the UDP is being copied in (which is why I thought it was working), but when I look in drawing B they do not show up.  The UDP Classification gets added, but the individual UDP does not.
*Expert Elite*
912 Kudos
Post 7 of 8
01-27-2015 02:44 PM in reply to: hbisco
Let me guess, your UDP's are String value UDP's? For whatever reason, these do not copy across drawings. Doubles, Elevations, etc., do copy correctly. I have no idea why this is.
Member
0 Kudos
Post 8 of 8
01-27-2015 02:55 PM in reply to: Jeff_M
Yes, most of them are String formats.
Interestingly, some of them are Elevation format so I dragged and dropped them in.  The first one copied through fine as did the UDP Classification, but the additional Elevation UDP items did not copy through, only the first one.
Oh well, it looks like I'll end up creating them all manually.  It's good practice anyway.
Thanks for your help Jeff_M!
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
