AutoCAD Civil 3D General Discussion
Active Member
mrbaze
Message 1 of 4 (144 Views)
Points that are in the same point group are imported into separate layers
144 Views, 3 Replies
10-31-2012 10:59 AM
I am running C3D 2010.
Somewhere along the line, someone in our office made our template import points into separate layers based on the RAW Description. I would like to un-do this. So far, I have deleted every point style & point label style except for 'Basic'. Inside of 'Basic', the layer is 'V-NODE'. However, some of my points are still coming in on layers like: 'V-Site-'(Raw Desc).
Can anyone tell me what is going on here?
I'm about to start from scratch on the template, however, I'd like to avoid that because of the array of styles that are in it.
Valued Mentor
Valued Mentor
sjg
Message 2 of 4 (143 Views)
Re: Points that are in the same point group are imported into separate layers
10-31-2012 11:07 AM in reply to: mrbaze
Thats based on your description key set in your template
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Active Member
mrbaze
Message 3 of 4 (133 Views)
10-31-2012 12:06 PM in reply to: sjg
Can you elaborate on that? Thanks again
Active Member
mrbaze
Message 4 of 4 (120 Views)
10-31-2012 12:58 PM in reply to: mrbaze
Figured it out, it was under Toolspace->Settings->Desc Key Sets
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
