C3D 2012 SP4
Win7 Pro
I want my survey symbols to come in on their own layers, separate from the point label. Here is how I approached it:
Lets use UPOL as an example:
I have a point style UPOL*. It has assigned to it a block representing the utility pole.
The size is set to drawing units, and sized to .1 inches.
The marker is on layer: V-NODE-POLE-SYMB
The label is on layer: V-NODE-POLE
The description key is as follows. Code: UPOL*
Style: UPOL*
Point Label Style: Standard
Layer: V-NODE-POLE-SYMB
No other parameters have been choosen; scale parameter, fixed scale, or use drawing scale.
Have I done this correctly, to accomplish my task? I also noticed that I cannot turn the point label off by picking it. I have to turn the layer off in the layer manager. Is this correct behavior?
Should I use the description keys to scale the symbol, instead of the point style?
Thanks for looking...
It's necessary if that's what you want to do. We still control ours via layering filters. I haven't played around much with controlling them through point groups. But what little time I did spend review as I couldn't see an easy way to accomplish our needs, it seemed like it wasan all labels on or all labels off scenario and that doesn't work well.
Mark Green
Working on Civil 3D in Canada
