Civil 3D Forum
Points set on Surface
4 REPLIES 4
elaine3051
369 Views, 4 Replies
I need to set a numbe rof points on an existing surface. Each point is giving me an elevation of 0.0 which of course is not the surface elevation. I'm sure this is a setting, but cannot find where the default setting is located. Thanks.
4 REPLIES 4
doni49
in reply to: elaine3051
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Jay_B
Is Points Creation>Prompt for Elevations set to "Automatic"?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
jmayo-EE
You can also assign elevations to the points after creation from the Modify tab of the Ribbon click the Point button. When the Contextual Points Ribbon displays you will see a button for Elevations from Surface.
John Mayo
jmayo-EE
in reply to: jmayo-EE
When I set manual points I will typically create one point, copy it all over the place and then use that comand to save time on the command line.
John Mayo
Rail Community
