i need to put points on the geometry points of an alignment. all i need is pc, pt, prc, pcc and radius and i need them labeled as such. is there a setting for that or does c3d just put points at all geometry points with no description and i've got to do it manually?
Solved by tcorey. Go to Solution.
I don't think there is an option to label descriptions based on geometry type.
Sorry,
Mike
Set your default description to Automatic-Object.
Settings tab of Toolspace, expand Points, expand Commands, right click Create Points and pick Edit Command Settings. Expand Points Creation and set Prompt for Descriptions to Automatic-Object.
Hey, that's it! Although you gotta strip out all sorts of junk from the descriptions:
Alignment - (1) - 0+00.00 - BOA
Alignment - (1) - 1+40.35 - RP
Alignment - (1) - 1+40.35 - PC
Alignment - (1) - 4+29.79 - PT
sweet. i looked for that but i guess i missed it. thanks.
