I've been trying to add survey settings to our Civil 3D template. Our surveyor created a file with the appropriate survey settings. When he imports a FBK file into his template, all the linework and points show up. But when he uses my combined template, some of the points from the FBK file aren't visible. Also, if he imports the same data as a CSV file, it displays all the points and lines correctly.
The surveyor prepared a template with just
Along with the appropriate label styles and a few other things.
We're stumped as to why the FBK data doesn't show up but the CSV does. All the points appear to be there, they show up in the point list. I don't know what settings I may have had in my general C3D template that might be throwing off the Survey data in the combined template.
Attached is the combined file with the error.
Thanks!
Rafael
Solved by Pointdump. Go to Solution.
Rafael,
"...some of the points from the FBK file aren't visible."
Which points? If your Description Keys aren't catching them, then they might be going into All Points, which you have set to None for both Point and Label Styles.
Dave
Dave Stoll
Las Vegas, Nevada
Rick Jackson
Survey CAD Technician VI
Yes, that was the problem. Trying to merge two different sets of template files makes for some interesting coordination issues! Always something to learn... Thanks for the help!
