Existing points in drawings show up on the screen but I cant LIST, EDIT or EXPORT.
When I ADD points in the same drawing all functions work correctly but only for the new material .
Any suggestions?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Are the points possibly in a locked Survey database?
Allen Jessup
from my nook tablet
Allen Jessup
CAD Manager - Designer
Joe Bouza
Joe Bouza
Joe. Mine says 8:27. Might want to check your settings or battery.
Allen
from my nook tablet
Allen Jessup
They appear on screen as POINTS.....Point number, description and label.
I can select them but NOTHING comes up.....no LIST, no STYLE....nothing.
I will do an audit and check if there is a database but cant do much today since I'm not at my work computer.
Any other suggestions?
Joe Bouza
Try selecting one of the items with the Properties Palette open.
If they are Civil 3D points it should say "Cogo Point" at top of palette, and if it says Cogo Point and Survey Point is "True" under data then it's also a "Survey Point".
Try using the point conversion utilities under the pulldown Points>Utilities; if they are ACAD or LDD points you can update them to C3D points.
