Is there a way to change the text for point table titles?
All I can get it to say is the default "Point Table"
Solved by rmitchler. Go to Solution.
Solved by AlmasSuljevic. Go to Solution.
Hi Mike,
You need to edit style. See below:
Have you selected the table right clicked on the table and chose edit table style. The data property table has text setting on it that you can change text styles. If you double click on the title header in the title block it brings up a text editor to change to anything you want.
Robert
So I take it you need to make a different table style everytime you want to change the title text?
I can make that work. Just doesn't seem very efficient.
Thanks for the replies.
The table title yes the data headers can be changed per table. You cannot update content however without it reverting. But yes a copy of the table style or new one is needed.
Robert
