Hi all,
I have a problem in Civil3d 2013 where at random I'll open up a drawing that previously had a point table created and all the point information has disappeared. All that remains are the Titles.
Has anyone else had this problem and has a solution?
Are you using sheet set manager? I remember hearing something along those lines in conjunction with sheet set manager. Can't remember what it was though.
No sheet manager in use. Point Tables just being inserted into the model space.
I have never had this issue, but here is some background to point tables.
Point tables can be created by selecting individual points, or a point group. They can also be static or dynamic. If your table was set to dynamic and the points get erased or removed from the drawing the table will go blank. Also if you selected to show a table from a point group and then remove points from that point group the tables will go away.
I hope this information helps with your issue.
I'm having problems with line & curve table data being lost. I was in a drawing that I had to reestablish the curve data early in the day and went back into the drawing later in the day and the data was lost again. The line work that is being labeled is from an XREF base drawing, just basic lines, not using parcels. The base drawing had not changes at all. Sometime I lose bearing & distance labels for property boundary and lot lines for plats.
Any ideas? This is frustrating.
Kevin
