Solved by jefflambert9091. Go to Solution.
Solved by wfberry. Go to Solution.
Agreed - this "zooming" of tables in PS can be very annoying. Quickest way is to change to another layout and then back to the original layout which automatically forces a REGENALL. Otherwise simply do a REGENALL in the layout.
That's a real pain in the you know what. But yeah that worked for me. Doing a regenall on the fly sometimes would change my drawing extends so bad it would move out of the paperspace view.
Hi-
The Point Group Table sure is handy (especially since it can update dynamically). However, they can be annoying due to their annotative nature, as you and others alluded to. As @wfberry recommended, keeping them in Model Space (off to the side) with a layout viewport is best, but if you need to have them in Paper Space, you may want to consider exporting your point group to a .csv. Then use “datalink” to link that .csv to a normal ACAD table. These tables do not behave the same as Civil 3D tables from a annotation scale perspective and may be an option for you to use in Paper Space. Please note that you will have to reexport your point group to overwrite the .csv each time you update points and update the data links, so it may not be worth it if you expect a lot of changes.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
I have had issues with doing that as well. One of the suggestions of going to another tab and back again works. pain in the butt but it works.
that's always an option if you don't think you data will change. Often in my case, my data changes often as some Engineers change their mind as often as they do their socks lol. This recent drawing, they changed 3 times in 1 week.
Like most said, create and keep your tables in modelspace then make a viewport. Also, try to be at the scale you will be plotting at when you create your tables. This will ensure you have the room and spacing. If you are not sure then give yourself some extra room. Also, once you have the viewports created vpfreeze what you don't need. This will keep the regen time down. I have very little trouble going this route.
Hello @WyldeParnelle
@Anonymous wrote:
Leave the table in Model Space. Make a window in paper space.
I agree with @wfberry and @jefflambert9091 that the best solution is leaving the table in model space off to the side with a layout viewport in paperspace. It will help with room on your design sheet, and it will keep the regen time down.
Wendell
