Hai I have a problem in point style using (_ddptype/ddptype) commands in civil 3D 2015.it says unknown command. I already run a “reset setting to default” but the problem is not solved. Actually what happens Autodesk rename that command or not? I know we can use pdmode, pdsizs etc..any budy can help. Where can I found the same command in pull-down menu or toolbars. I want to see the point style wizard to make modification easily.
Solved by Jeff_M. Go to Solution.
This might also be useful for you:
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-5647ACE3-412E-48A6-8C1B-6B0EE09F5E3F
