Hello, I have encountered a problem where change of point group style won't effect for some points. This happens to points I created a while back. Those created recently do not have a problem. Any ideas on how this can be surmounted.
Solved by doni49. Go to Solution.
Solved by Pointdump. Go to Solution.
Ed,
Have you clicked them on in the Overrides Tab of the Point Group?
Dave
Dave Stoll
Las Vegas, Nevada
So point group A contains points. You change the point style assigned to point group A and the points dont seem to change?
My first guess would be that the points themselves have overrides set (so that they define the point style vs getting their style setting from the point group. Second guess would be that the points in question are also part of another point group that's higher in the priority list. The higher one in the list would control its display.
If neither of these help, please post a dwg file for someone to look at -- and note the version you're using./
Don Ireland
Engineering Design Technician
Thanx for replies guys and apologies for the late follow up,
I got it. it was the overrides. Somehow they got unchecked for the groups. So I checked them and "viola", all was back to normal
thanx
