Active Contributor
FrustratedCadder
Message 1 of 9 (295 Views)
Point Style Defined by Parameter $1
295 Views, 8 Replies
12-31-2012 12:57 PM
I have looked high and low and can't find an answer to this.  Does anyone know if it is possible to have the point style for a shot match on Parameter $1 instead of $0?  For example on the following codes:
STORM MANHOLE
STORM INLET
I would like the Point Style for the first example be a manhole and the Point Style for the second be an Inlet.  As far as I can tell, there is no way to have it look past the first parameter "STORM" when defining the Point Style.  Is this correct?
You're right. You would have to eliminate the space in the description. You can use _ or -, but the space tells Civil 3D that the description code is finished. It will read additional parameters for size and rotation values only. I can see where you're trying to go and that would be a nice feature....
tcorey
Message 2 of 9 (292 Views)
Re: Point Style Defined by Parameter $1
12-31-2012 01:16 PM in reply to: FrustratedCadder
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
FrustratedCadder
Message 3 of 9 (291 Views)
12-31-2012 01:19 PM in reply to: tcorey
That's what I was afraid of.  :smileysad:  I was hoping to simplify our coding process, but it looks like it may not work the way I wanted it to.  I was hoping I was missing some really cool and secret wild card or something.
TRogers
Message 4 of 9 (287 Views)
12-31-2012 01:23 PM in reply to: FrustratedCadder
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Active Contributor
FrustratedCadder
Message 5 of 9 (280 Views)
12-31-2012 01:34 PM in reply to: TRogers
Hey Todd!  Didn't figure you'd be in today.  Specifically, what I am trying to do is convert our existing codes (from the LDD and Softdesk days) to take better advantage of the .FXL file format supported by Trimble.  As in the example you posted, things like Trees are no problem.  I can set the one code 'Tree', to fall into the 'Vegetation' point group and assign the 'tree' symbol to it, put it on the Vegetation layer and then use the parameters afterwards for my label style.  What I was hoping to be able to do was create a master category i.e. STORM in which those points would fall into the Storm point group, on the Storm Blocks layer BUT then read parameter $1 (MANHOLE, GRATE INLET, BB INLET, etc) to define the point style associated with that shot. I can definitely use the underscore or dash option, it just doesn't allow me to re-use as much of my current setup as I would like.  Thanks for the help!
tcorey
Message 6 of 9 (271 Views)
12-31-2012 01:36 PM in reply to: TRogers
Thanks Todd. I learned something new today!
Tim Corey, Owner
Redding, CA
TRogers
Message 7 of 9 (268 Views)
12-31-2012 01:38 PM in reply to: tcorey
LOL...i learn something new everyday from all you guys!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Distinguished Contributor
SurveyorLee
Message 8 of 9 (223 Views)
01-01-2013 04:54 PM in reply to: FrustratedCadder
yes,
use STORM M* for one
and STORM I* for the other
You may have a 6 character restriction.  IF you do, change it to "STRM M*" an STRM I*
I use STMH and STMI to differentiate them.
This should work.
Surveyor Lee
Active Contributor
FrustratedCadder
Message 9 of 9 (203 Views)
01-02-2013 06:34 AM in reply to: FrustratedCadder
Hey Lee,
Thanks, I think that is what I will end up doing.  Not as clean as I would have liked, but still an improvement!  Thanks!
