Member
BombthePeasants
Message 1 of 8 (343 Views)
Point Sorting Progress Bar always on
343 Views, 7 Replies
04-25-2012 07:09 AM
Dear Sirs and/or Madams,
I am experiencing a relatively new and maddening AutoCAD problem. If I manipulate any point, or select a point group, or perform ANY action involving points in my drawings, a "Sorting" progress bar appears in the lower left hand corner of the screen, and if it's a drawing with a substantial amount of point data, it can/will lock my computer up. This is driving me bonkers! Can someone explain to me what is going on, and help me find a solution?
Thanks in advance,
ERIK
attached herein is an image of the progress bar.
sboon
Message 2 of 8 (334 Views)
Re: Point Sorting Progress Bar always on
04-25-2012 08:21 AM in reply to: BombthePeasants
Do you have any surfaces or corridors on Auto-Rebuild?
Member
BombthePeasants
Message 3 of 8 (331 Views)
04-25-2012 08:41 AM in reply to: BombthePeasants
I do, and have always had them in the past, but this is a new problem, as in only about 2 weeks ago.
sboon
Message 4 of 8 (318 Views)
04-25-2012 10:31 AM in reply to: BombthePeasants
I believe that the sorting message refers to the TIN points within a surface.  The software needs to sort them as part of the surface build process.  Normally the operation is so fast that you never see this message, unless it's a very large surface.  I usually see it with Lidar datasets.
watersam
Message 5 of 8 (312 Views)
04-25-2012 11:19 AM in reply to: sboon
This same problem frequently occurs in drawings where my points are not included in a TIN.  I am also going bonkers.  It seems to be a recent problem for me as well.  Is there a point setting that can eliminate the constant sorting?
Sam
sboon
Message 6 of 8 (309 Views)
04-25-2012 11:35 AM in reply to: watersam
The points being sorted are not your cogo points in the drawing.  They are the TIN points which are within the surface.
watersam
Message 7 of 8 (306 Views)
04-25-2012 11:45 AM in reply to: sboon
I have a drawing with absolutely nothing but the points I just imported in it.  There's a lot of sorting going on.  Seems that getting out of Toolspace stopped the problem, but that's an issue for anyone who does have a surface in their drawing.
New Member
RichShine4634
Message 8 of 8 (282 Views)
04-27-2012 02:07 PM in reply to: BombthePeasants
Was having the same issue, so from the Prospector Toolspace, right click on POINTS, then select "Refresh", I have not had an issue since.
Hope this helps.
Rich
