Civil 3D Forum
Point Sorting Progress Bar always on
12 REPLIES 12
Message 1 of 13
BombthePeasants
2255 Views, 12 Replies
Dear Sirs and/or Madams,
I am experiencing a relatively new and maddening AutoCAD problem. If I manipulate any point, or select a point group, or perform ANY action involving points in my drawings, a "Sorting" progress bar appears in the lower left hand corner of the screen, and if it's a drawing with a substantial amount of point data, it can/will lock my computer up. This is driving me bonkers! Can someone explain to me what is going on, and help me find a solution?
Thanks in advance,
ERIK
attached herein is an image of the progress bar.
12 REPLIES 12
Message 2 of 13
sboon
in reply to: BombthePeasants
Do you have any surfaces or corridors on Auto-Rebuild?
Steve
Expert Elite Alumnus
Message 3 of 13
I do, and have always had them in the past, but this is a new problem, as in only about 2 weeks ago.
Message 4 of 13
sboon
I believe that the sorting message refers to the TIN points within a surface.  The software needs to sort them as part of the surface build process.  Normally the operation is so fast that you never see this message, unless it's a very large surface.  I usually see it with Lidar datasets.
Steve
Message 5 of 13
watersam
in reply to: sboon
This same problem frequently occurs in drawings where my points are not included in a TIN.  I am also going bonkers.  It seems to be a recent problem for me as well.  Is there a point setting that can eliminate the constant sorting?
Sam
Message 6 of 13
sboon
in reply to: watersam
The points being sorted are not your cogo points in the drawing.  They are the TIN points which are within the surface.
Steve
Message 7 of 13
watersam
in reply to: sboon
I have a drawing with absolutely nothing but the points I just imported in it.  There's a lot of sorting going on.  Seems that getting out of Toolspace stopped the problem, but that's an issue for anyone who does have a surface in their drawing.
Message 8 of 13
Was having the same issue, so from the Prospector Toolspace, right click on POINTS, then select "Refresh", I have not had an issue since.
Hope this helps.
Rich
Message 9 of 13
CADmgrMike
in reply to: RichShine4634
Here it is 2017 and I'm having the same issue with C3D 2017.
I have a drawings with points and no surface.
I have right clicked on Points and hit Refresh.
Everytime I manipulate a point label, I get this point sorting bar.
It's taking forever to do anything.
Mike Porter
https://provostandpritchard.com/
Message 10 of 13
CADmgrMike
in reply to: CADmgrMike
I found another post with a fix. Sort your points by Point Number and the sorting will go away.
Mike Porter
Message 11 of 13
I just want to thank your for this. I remember seeing it. Hasn't happened to me until today. Such a simple fix for something so aggravating!
Jeff
Civil 3D 2024
Message 12 of 13
I have this same problem in a drawing I took over. How do I change the setting to sort by point number? Thanks in advance!!
Tags (1)
Message 13 of 13
I figured it out.
Rail Community
