>>Points in Civil3D are not objects, they are simply data
that's an interesting statement, because when you list
the point, under "Select objects:" you get both in the list:
AECC_POINT_GROUP and
AECC_COGO_POINT
thanks,
Strah @ Langan
"Daniel Slater" wrote in message
news:D3DE285CE68296A853A43FFA1CE59AB2@in.WebX.maYIadrTaRb...
> Kevin,
> Points in Civil3D are not objects, they are simply data - this saves
> us over 90 bytes per point - the point group is the object. This is
> what's causing the behavior you're seeing in 3DORBIT and Object Viewer.
> The window selection issue is a known defect we're looking into.
> Dan Slater
> Kevin Breslin wrote:
> > For viewing functions and in some cases selecting points to create a
group
> > for example you will see strange behavior.
> > For example, if you import points from a file, select one point by an
> > implied window then use 3DORBIT or Object Viewer you will get all of the
> > points not just the one you selected. Also, when selecting points for a
> > point group by selecting points in the drawing, you will get nothing if
you
> > make an implied window, however if you make an implied crossing window
the
> > program will accept the points.
> > Kevin Breslin
