Valued Contributor
bo.martin
Message 1 of 5 (283 Views)
Point Number Issues in C3D 2013
283 Views, 4 Replies
10-11-2012 11:31 AM
Argh!!!!!!
It doesn't matter where you set the Next Point Idenity
In the Create Points dialog Box or The Command Settings
Choose Create Points Interpolate and it resets to the lowest point number avaliable.
Or.....
Renumber some points that got entered wrong (From above problem)
now try to create a point manualy
the numbers already exist so instead of renumbering automaticly all you get is NOTHING!!!
You have to reset the next point number. And if you enter a number that exist all it tells you is
"Point Number Must be Unique"
AUTODESK FIX THIS PLEASE!!!!!
As if there aren't enough time wasters built in :-)
BrianHailey
Message 2 of 5 (264 Views)
Re: Point Number Issues in C3D 2013
10-11-2012 01:51 PM in reply to: bo.martin
Did you submit this to Autodesk support?
Brian Hailey
CAD-1.com
My Blog
Valued Contributor
bo.martin
Message 3 of 5 (253 Views)
10-11-2012 03:35 PM in reply to: bo.martin
Look all over.
Can't find a place to email Autodesk.
Jeff_M
Message 4 of 5 (249 Views)
10-11-2012 03:44 PM in reply to: bo.martin
I think THIS is the same issue, which Autodesk is aware of.
Valued Contributor
bo.martin
Message 5 of 5 (243 Views)
10-11-2012 03:53 PM in reply to: bo.martin
Thats it exactly!!
