Civil 3D Forum
Point Marker Styles
5 REPLIES 5
Isabel
151 Views, 5 Replies
Point Marker Styles
Hello all!
I've been looking in the last topics for something about how to add new blocks to the Marker Styles from the Multipurpose Styles Collection, and found nothing. I know how to edit the styles but the blocks available in the Block Id list are not enough.
Thanks.
5 REPLIES 5
in reply to: Isabel
Isabel,
The block id lists are dynamic and display the names of all the blocks in
the current drawing. If you need an addition block, first make the block
using the standard AutoCAD "block" command, or bring in a block from disk or
another drawing. After you're done, the new block will display in the
dropdown list.
Cheers,
Peter Funk
ACADuser
in reply to: Isabel
Hi Peter,
Can you please include the ability to add blocks from drawings contained in a user specified default folder in a future release of Civil 3D ?
This way standards are easier to maintain. Currently if I wanted to make a change to a block, I would have to change the bock definition in each drawing template (we use several).
Thank You
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
in reply to: Isabel
Hi Peter,
In support of this suggestion, relying on having blocks in the drawing which
may or may not get used (and, quite likely, could get purged before being
wanted) seems to create an unnecessary overhead to Civil 3D.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:4811317@discussion.autodesk.com...
> Hi Peter,
> Thank You
in reply to: Isabel
Which at the end of the day leads us back to REALLY wanting a C3D file
that we CMs could use to drive styles, etc. It should be part of the
project structure to allow styles to be selected from the project....
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT2005SP1 & C3D2005SP1
Laurie Comerford wrote:
> Hi Peter,
in reply to: Isabel
All great suggestions! I'll make sure that they're all incorporated into our
thinking for future releases.
FYI, if the block is referenced by a style, then it can't be purged.
Cheers,
Peter Funk
Rail Community
