Civil 3D Forum
Point Marker Size
4 REPLIES 4
Pointdump
13275 Views, 4 Replies
Point Marker Size
On the Marker Tab of my point style, I set the Marker Size to 0.05".
Then on the Summary Tab, under the Marker Node, the Point Marker Size shows 0.004". If I change that to 0.05, like I have it on the Marker Tab, the point marker becomes huge. Why aren't these two settings the same?
Another question. When I reduce the Marker and Label sizes, the label doesn't "suck in" to the marker. How can I bring the label closer to the marker without dragging it?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
4 REPLIES 4
charles.neely
in reply to: Pointdump
Use the point group properties to change the positioning of the text. The x-offset and y-offset are the settings you want to edit.
Pointdump
in reply to: charles.neely
Hi Charles,
OK, I see now. I have to change the X & Y Offset on the component that attaches to the feature.
Huge help. Thanks much.
Dave
Dave Stoll
Las Vegas, Nevada
mconway
The reason your sizes are different is that you have the Marker size set to a fraction the drawing scale. If you set your Marker to Use Fixed Scale the numbers will match.
At your service,
Mark A. Conway
Director - Applied Technology
Autodesk Certified Instructor
AutoCAD & Civil 3D 2014 Certified Professional
Infrastructure Design Suite BIM Specialist
Follow me on Twitter @CADventurer
Pointdump
in reply to: mconway
Mark,
You are so right! I never noticed that. I normally use Drawing Scale to size my Marker. The Use Drawing Scale Size in the Marker Tab of Point Style is in Inches. The Point Marker Size under Marker in the Summary Tab is in Feet. 0.004'=0.05"
So if I set the Marker to Use Fixed Scale, then they do indeed match. Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
