I import a text file. I look at the coordinate list in the toolspace under the survey tab and the coordinates listed are correct. but the nodes in the drawing are 4 feet off. any idea as to why this is happening?
Post a copy of the drawing to this forum. Someone will be able to look at it and probably give you an answer.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Mike,
If the coordinates listed are correct, what is 4 feet off? And yes, please post a drawing.
Dave
Dave Stoll
Las Vegas, Nevada
this sounds like the difference in international feet vs. US feet, or at least in SC it's between 4 and 5 feet.
Surveyor Lee
My zone setting was correct but my database setting was wrong. The funny thing is that I worked in a different project and didnt have this problem. Not sure how it happened.
