What point group is it in?
Quick pointers on how your point appearance is determined:
1) Point Group Layer (unless it is set to Layer 0).
2) Layer in Point Label Style (label only) (unless it is set to Layer 0).
3) Layer in Point Style (unless it is set to Layer 0).
4) Point Layer (as assigned in the Description Key)
Also, there is a bug with the Autocad Custom Markers, where they do not get the correct Plot Style (STB only) or Plot/NoPlot settings (STB or CTB). Instead, these settings always come from the Point Group Layer. You can work around this issue by avoiding Autocad Custom Markers, and using Blocks that you create instead.
Sinc
