So here is what I am trying to do.
I have point lable style to show my point numbers for my control and property corners. As shown below.
I am working on a survey control sheet that will show all my control with point numbers. I have been using Point Label styles to to this.
WhenI have points that are two close together the labels will be overlapping. I take care of this by dragging the label. Which works well.
However when I have multiple sheets to my and have different scales and the same points being used in the different viewports at different scales and I drag them to correct the overlapping issue. It does not always look the way I want in each viewport. Because in a large scale view port when drag the label to look good with and arrow and etc..... It does not look good on other sheets with different scales.
I use point groups and overides for the lable sytles. I wish I could set the Hireachy of the Point displays thru each individual viewport.
I am looking for suggestions of what others do in similiar situations.
