AutoCAD Civil 3D General Discussion
Active Member
0 Kudos
Post 1 of 11
Point Lable at elevation
1773 Views, 10 Replies
09-26-2011 01:58 AM
Hi
I am a newby in Civil 3D :smileyhappy:
I have some point style that set "Use Point Elevation" and some Label Style that set together in my Description Set keys.
after insertion of point both point and lable are in elevation until i explod them. after explode label go in elevation zero. i want them remain at elevation. is there any way to do this?
thanks for any help
Active Member
0 Kudos
Post 2 of 11
Re: Point Lable at elevation
09-26-2011 11:42 PM in reply to: omidiii
is it impossible or i'm only one that want do that?
*Expert Elite*
343 Kudos
Post 3 of 11
09-27-2011 12:04 AM in reply to: omidiii
why do you need/want to explode these??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
*Expert Elite*
485 Kudos
Post 4 of 11
09-27-2011 05:02 AM in reply to: omidiii
You may be the only one doing this. Exploding a point destroys it's usefulness. What are you trying to accomplish?
Allen
Valued Mentor
39 Kudos
Post 5 of 11
09-27-2011 05:13 AM in reply to: omidiii
If you need it in just AutoCAD elements, ie lines and text, use 'Export to AutoCAD'. The results will be better.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Active Contributor
9 Kudos
Post 6 of 11
09-27-2011 11:32 AM in reply to: omidiii
You can explode your points if you want to. I some times explode points to keep just  blocks inserted with the description. The elvations don't change. There should be some settings in your drawing that affect your elevations. Try to insert your points to  vanilla autocad (not civil 3d) and explode.
Windows 7 Pro x 64
16 GB Ram
Intel Xeon E3-1220 V2 @ 3.1 GHz
NVIDIA Quadro 600
Civil 3D 2013
Active Member
0 Kudos
Post 7 of 11
09-28-2011 01:50 AM in reply to: omidiii
i need that because some office work with Autocad 2007 and need drawing be explod.
@ yosephk: are point lable keep elevation after explod? my problem is'nt block point. just labels go on 0 elevation.
i tried export to cad 2007 and cad 2007 dxf with no result.
thanks for any suggestion
Active Contributor
9 Kudos
Post 8 of 11
09-28-2011 05:48 AM in reply to: omidiii
Yes, the elevation label will be there after it is exploded. But it will be just  text. It can not be used for surface creation. If that is the case re-import your points  to a new point group with elavation lebel style. Also check if your points are comma delimited or space delimited.
Windows 7 Pro x 64
16 GB Ram
NVIDIA Quadro 600
Civil 3D 2013
*Expert Elite*
485 Kudos
Post 9 of 11
09-28-2011 05:57 AM in reply to: omidiii
To move text to elevation use Move Text to Elevation.
To convert cogo point to blocks use Create Blocks from COGO Points.
Allen
Active Member
0 Kudos
Post 10 of 11
09-29-2011 06:29 AM in reply to: omidiii
Hi again
thanks AllenJessup,
Move Text to Elevation only help for elevation label, i have a description label too.
Create Blocks from COGO Points Also want a Point Number and i dont want it.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
