I imported survey points into a drawing and created a number of point groups. When I add specific points to specific point groups, the labels change. For example, labels for points with codes "BLDG" change to "building" and points labelled "SLT" and "SLB" change to "sanitary line". When I click on a point to check its properties, the original description is listed - it's just different on the screen. The elevations don't seem to change, just the labels. What could be causing this to happen?
The label style in the point group is probably set to label Full description, and upon import, the description key format is changing the Raw description, BLDG, to the Full description building as well as changing the SLT and SLB Raw desc. to the Full desc. sanitary line.
HTH
AWood
