I have an issue that I have not been able to resolve. I placed some spot shots in my base drawing for a project using point creation with description keys and label styles. I need the points to show in a viewport that is in another drawing, so the base drawing is xref'd into the layout drawing. These shots were so small in the layout, that I had to adjust my label style to display the points at 1" in order to make them legible when plotted. The points in the base drawing are now so large that they are impossible to read or edit. What did I do wrong? Is there a scale factor that I can use to make the display uniform in the base and xref drawings? The viewport that I am concerned with is set to 1"=40'.
