graphtype
Message 1 of 5 (460 Views)
Point label style in Pspace significantly smaller than Mspace
460 Views, 4 Replies
01-02-2013 10:12 AM
Hi there!
I'm a bit new to the concepts of point labels in C3D; I browsed around for a bit for a solution and haven't been successful. I'm having troubles with my point label styles in Paperspace - they appear about 25x smaller than in model space, but both are the same scale.
This is my label style setup:
This is how it appears in modelspace:
This is my viewport settings and how it appears in paperspace (zoomed in):
The text height in MS is 2mm, and approx 0.078mm in PS.
Any assistance would be greatly appreciated.
--Lawrence.
Check the Units in the page setup for the layout.  They need to be set to the same units as your layout.  (Looks like you're in mm, these units often get reset to inches so that's where I'd check first.)
TRogers
Message 2 of 5 (450 Views)
Re: Point label style in Pspace significantly smaller than Mspace
01-02-2013 11:05 AM in reply to: graphtype
They should automatically "size" themselves based on the scale of the viewport.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
troma
Message 3 of 5 (437 Views)
01-02-2013 11:40 AM in reply to: graphtype
Credit where credit is due! Give kudos or accept as solution whenever you can.
coopdetat
Message 4 of 5 (430 Views)
01-02-2013 11:55 AM in reply to: graphtype
I had a similar (maybe identical) problem that was isolated to the plot device in the page setup I was using.  Specifically, if the plot device is a raster plot device, that will cause the problem.  I worked directly with some Autodesk engineers to identify the cause.  They acknowledged (confirmed) that raster device was the source of the problem... there was no projection regarding when the issue would be fixed.  My conclusion was that the improper treatment of raster output as "dimensionless" led to the faulty coding that  causes this problem. Dots-Per-Inch (dpi) is an explicit dimension that should be applied to the raster output but it is not.
The prior discussion is here: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Improper-scaling-of-point-label-styles-using-quot-dim...
P.S. it turns out the the difference is a factor of 12, I don't know why.  If you change the plotter in the page setup to a typical plotter (HP, etc.) my problem would go away.  Not a good solution for me because I always plot to TIFF, a raster format and I can't plot w/o the problem in the way.
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 7 Professional 64-bit - Service Pack 1
Intel﴾R﴿ Core﴾TM﴿ i7-3820 CPU 3.60GHz; 16 GB DDR3 Dual Channel RAM
nVidia Quadro 4000; AutoCAD Civil 3D 2014, sp1
graphtype
Message 5 of 5 (388 Views)
01-03-2013 08:10 AM in reply to: troma
Thanks guys. Troma was right - the page setup units somehow got changed from mm to inches and simply changing that fixed the size. I kept trying to figure out what was wrong with my point label style but couldn't find anything.. that was a simple fix haha.
--Lawrence.
