We are using C3D 2014.
I have some points with a label style that is set to 0.10 text height in layout and in dragged state. However, the text height of the non-dragged state is larger than the label height of the dragged state. With the style settings label height set at 0.10, what would likely control this behavior?
Solved by Jay_B. Go to Solution.
Check on the Dragged State Tab within the Point label style being used.
Under the Dragged State Components property is the "Text Height" here set to a larger number than 0.10? I'm guessing so.
