Active Contributor
lhampton
Message 11 of 13 (71 Views)
Re: Point Insertion (without defined desc. key) into a Specific Layer
05-14-2012 01:20 PM in reply to: stacy.dunn
Awesome, thanks again... My order was right after I checked it, turns out it was a style attached to the _AllPoints group, I added this earlier trying to solve my first problem, deleted the style and its working now.
Now I need to figure out how to insert correctly sized trees according to description (as you can see from my pic above) the descriptions read like "trd 5.3 8", stands for Deciduous Tree (trd) 5.3" diameter at breast height by 8ft dripline, i need a deciduous tree symbol (block) inserted and scaled to the 8ft dripline at the node... Any links you suggest i read?
Intel i7 2600 /z68 Gigabyte
8gigs DDR3 1800
Intel 320 Series SSD
Quadro 600 (1gig)
C3D 2013 / LDT 2009 / Win7 x64
Valued Mentor
stacy.dunn
Message 12 of 13 (66 Views)
05-14-2012 01:28 PM in reply to: lhampton
Description keys work the same way they did in LDD.  You can choose a parameter ($2) to use as a scale factor for the symbols.
Stacy Dunn
Active Contributor
lhampton
Message 13 of 13 (60 Views)
05-14-2012 02:03 PM in reply to: stacy.dunn
Once again, thanks for the help, i was able to get the desc key in there for the scaled trees no problem after looking at my old file.
Thanks Stacy you are truly an angel!
8gigs DDR3 1800
Quadro 600 (1gig)
