We set up a dwt that has about 100 empty point groups to use. Once points have been imported into our drawing we place our points in their respective group. If someone creates a file without using our template, can these point groups be pulled in afterwards? I have tried landxml and it looks like they can be dragged and dropped individually but this is pretty tedious
Qnew from your template or drawing1 if it is created at startup >> go to tthe settings tab>> highlight the template created drawing>> expand points>> groups drag and drop
or create new from template and insert the drawing you want updated with the groups
Your Name
The best thing is to insert the drawing that doesnt' have the Point Groups in to a blank drawing created from your template. This will not only cover the Point Groups but all the Styles and Settings that are likely missing as well.
Allen
Allen Jessup
CAD Manager - Designer
Your Name
Same to you and your's Joe.
Happy New Year to every one out there!
Allen
Allen Jessup
Thanks Joe, This method works but it seems that you have to drag them one by one. Do you know if there is a way to dump them all in at once?
