there's a joke somewhere there about a priest and a laptop, but I ain't
gonna try it.
Good luck, John. Haven't seen that one before, maybe it won't be too hard
to get rid of.
Jason Hickey
Engineered Efficiency, Inc.
www.civil3d.com
www.eng-eff.com
"John Mayo" wrote in message
news:5825756@discussion.autodesk.com...
Only 33 groups list in prospector. The remaining are ghosts. Will try
exorcism next. 😉
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"Jason Hickey" wrote in message
news:5825750@discussion.autodesk.com...
Are they all displaying in Prospector? Or are they just "there" but not
"there"? If the latter is the case, would it just be acceptable to
ignore the problem? I know it's irritating having them there and not being
able to get rid of them, but as long as they're not displaying and not
causing any problems, I would just leave them...
Wow, that template has been around the block, eh?
Jason Hickey
www.civil3d.com
www.eng-eff.com
news:5825693@discussion.autodesk.com...
A number of times Jason.
I think this template began on 06. I have dragged & dropped everything under
the sun into this file.
The one I was working on this weekend was a copy of the template we
currently use. I opened the template we currently use (33 point groups) and
it list 649 point groups. Therefore the template I copied this weekend had
the funky point groups double.
The work I did on the copied template was nothing more than changing point
styles to layer zero & setting up some layer control. I was also editing
default object layers.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
news:5825689@discussion.autodesk.com...
That's a strange one, John. I just opened a blank drawing, imported some
points (all points was created) then created my own point group - I deleted
my point group, ran qselect, it was gone. I saved the drawing, closed it,
reopened, the point group did not reappear when I used qselect again. I
would assume that you've audited and recovered the template?
Jason Hickey
www.civil3d.com
www.eng-eff.com
news:5825698@discussion.autodesk.com...
I was working on our template this weekend and did a select all. The
properties dialog listed 1400+ point groups. My template has 33 point groups
defined. I cannot delete the point groups.
I had two groups that I renamed. I saved the dwt & reopened it. The 2 point
groups that were renamed are there but the two original groups have
reappeared. In other words, I renamed 2, saved, opened & found 4.
Does anyone know how to purge these out or correct these issues? Has anyone
else seen this?
I have purged, used Quick Select to try to erase them, purged regapps,
audit, recover. The point groups are not really assigned to any c3d object
as a property. Even so I did go though the file & try to find some sort of
style or setting dependency. I could not find any.
Any and all suggestions (short of me flying a kite) are greatly appreciated.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
