And yet there is a button to make the surface update automatically, except
of course when the damn point group gets out of sync. So I believe the point
groups should at least give you the option to automatically update. And then
there are the key descriptions, which doesn't update the point symbol unless
you actually reimport the point (or manually reassign the point style with
vba, which was my workaround). c3d is supposed to be dynamic.
Jon
wrote in message news:5535851@discussion.autodesk.com...
The all points group shows all points all the time, it doesn't really update
in the sense that other point groups update by the criteria they are defined
by. Getting all point groups to update after each little change to a point
would bog the system down, that's why it's not automatic. Given that Civil3D
is generally designed for PCs that haven't been built yet, I'm happy to
update manually as and when needed.
What would be an idea is an "Update/Recalc Everything" button somewhere that
makes sure everything in the project is up to date.
