Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Point File Format Listing
3 REPLIES 3
dtucker
327 Views, 3 Replies
Is there a way to re-order the point file format listing  for points on the settings tab? I have tried everything and it will not change the order of the listing.
3 REPLIES 3
BrianHailey
in reply to: dtucker
Not that I'm aware of. At first I thought it might have something to do with the order the format was created but that didn't work either. Two formats created right after each other, one named "aaa" and the other named "aaaa" showed up in two different places in the list.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
in reply to: BrianHailey
Not sure the ryme or reason, but if you right click and go to properties, then press ok. some of the files will move in the list. it grouped the PNEZ together.
I deleted all of the ones I don't use from the list-which was all but 4.
David
Rail Community
Ā
Ā
