Civil 3D Forum
point file causes crashes in survey
7 REPLIES 7
Message 1 of 8
randcdavidson
290 Views, 7 Replies
I took the following point file into my drawing using the survey import. It will crash C3D 2103 everytime if I process linework. Can someone verify this for me?
1,5551.9964,5352.9989,251.670,EP BEG BC H0.1 V0.5 H0.5 H25 V2
2,5513.9965,5390.9997,249.637,EP
3,5551.9963,5428.9989,247.604,EP
4,5589.9964,5390.9999,249.637,EP RPN1 EC
7 REPLIES 7
Message 2 of 8
tcorey
in reply to: randcdavidson
It works fine for me using the Sample linework code set. No crash.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
randcdavidson
in reply to: tcorey
Really? I had to change the EP BEG BC H0.1 TO H0.5 or greater. It does not like the 0.1 for some reason when processing linework.
Message 4 of 8
Jeff_M
Worked for me as well with the original sample.
Message 5 of 8
BrianHailey
in reply to: Jeff_M
Jeff,
Shouldn't the "BC" portion of the description begin a curve? Your figure doesn't have any curves on it. I don't have C3D on this system so I'll have to try it out later.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 6 of 8
Jeff_M
in reply to: BrianHailey
Yes, I thought so, too, Brian. I just didn't have time to look at why it didn't...I just wanted to report that it didn't crash with the 0.1 offset distance.
Message 7 of 8
Jeff_M
in reply to: Jeff_M
Ah, the Sample Linework code set has B as the begin code, whereas the text file used BEG. I changed the code set and got this:
Message 8 of 8
BrianHailey
in reply to: Jeff_M
That looks better. Didn't notice the change in the begin code. If I remember correctly, the begin code in field book files is BEG so it makes sense as to why that was used here. That's one nice thing about the Linework Code Sets, you can set the codes to whatever you want.
GEI Consultants
My Civil 3D Blog
Rail Community
