Thought I understood point styles and overrides, but things are not appearing as I would expect. I have a dwg with three Point Groups (V-EG-SURFACE, V-TOPO and _All Points). All the points come from a Survey Database. V-TOPO is used to control what is displayed on the plans, V-EG-SURFACE contains points only used for the surface. In the Prospector tab by right-clicking on Point Groups and selecting Properties, V-TOPO has been moved to the top of the list, V-EG-SURFACE second and _All Points third. V-TOPO does not have any Overrides selected and I would expect points to be displayed as brought in from the Survey Database. V- EG-SURFACE has the point style and point label styles set to no display with the Overrides checked. _All Points does not allow setting Overrides (?I can change this in other dwg's). The issue I'm having is there are some points included in V-TOPO that are not displaying. This continues to occur even when Overrides are turned off in all three Point Groups. The points in question have a Point Style set to no display and a Label Style set to display. All layers are on and thawed in model space. If I set the override in V-TOPO to a label style that displays (including the one used for the points in question) the missing points display.
Hope this makes sense and someone can offer me suggestions.
Thanks in advance.
C3D 2011, 2013 (latest updates)
Win 7 Pro, 64-bit
16 GB RAM
Solved by Jeff_M. Go to Solution.
Is the PointStyle set to show the Labels?
Thanks, that fixed the issue. Thought I had looked at the display. Guess I assumed it was on so therefore saw it as on the first time I look.
