In LDDT 2009, I was able to describe points like this: STK #32
But in Civil 3D 2013, whenever I use the # symbol, the description gets truncated. So, using the point description above, it will show up in Civil 3D 2013 as STK rather than STK #32.
Is this a setting or something that I can switch on so that the I can use symbols such as # and - in my point description?
Are you using Description Keys? If so, check the Format column of the description key that is not working. Try setting that to $* and see if you get the # sign.
It's possible that you have Raw description being called rather than Full Description. Check the Contents of the Description component of your label style.
I got it to work. I changed it to Raw Description, reimported the points and it showed up they way I wanted to.
Thanks for your help.
