Valued Contributor
rkmin
Message 1 of 7 (147 Views)
Point Description gets truncated
147 Views, 6 Replies
11-28-2012 09:11 AM
In LDDT 2009, I was able to describe points like this: STK #32
But in Civil 3D 2013, whenever I use the # symbol, the description gets truncated.  So, using the point description above, it will show up in Civil 3D 2013 as STK rather than STK #32.
Is this a setting or something that I can switch on so that the I can use symbols such as # and - in my point description?
I got it to work.  I changed it to Raw Description, reimported the points and it showed up they way I wanted to.
Thanks for your help.
tcorey
Message 2 of 7 (141 Views)
Re: Point Description gets truncated
11-28-2012 09:41 AM in reply to: rkmin
Are you using Description Keys? If so, check the Format column of the description key that is not working. Try setting that to $* and see if you get the # sign.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
rkmin
Message 3 of 7 (139 Views)
11-28-2012 09:54 AM in reply to: tcorey
Yes, I checked the description key format and it is set to $*.
Valued Contributor
rkmin
Message 4 of 7 (131 Views)
11-28-2012 10:04 AM in reply to: rkmin
Is it something to do with the Point Label Style for "description" that I have to change?
tcorey
Message 5 of 7 (126 Views)
11-28-2012 10:08 AM in reply to: rkmin
It's possible that you have Raw description being called rather than Full Description. Check the Contents of the Description component of your label style.
Tim Corey, Owner
Redding, CA
Valued Contributor
rkmin
Message 6 of 7 (124 Views)
11-28-2012 10:14 AM in reply to: tcorey
It was already set to Full Description.
Valued Contributor
rkmin
Message 7 of 7 (122 Views)
11-28-2012 10:18 AM in reply to: rkmin
